1985 Glastron SSV151 90Hp Mercury 6cyl
jay127
I bought this boat and had a few questions. What avg speed should i expect from this boat? Should it be able to pull a tube and a wallboard. Also are the 6cyl mercs reliable. I appreciate any help you can provide.
Thanks
Jeffrey Darling
26aftcab454
Re: 1985 Glastron SSV151 90Hp Mercury 6cyl
pullin' the tube should be fine but those wallboards are pretty tuff..
sorry could not help it
I would think 45-55MPH- have fun & good luck!:cool:
jay127
Sorry i always use spell check and i wasn't paying attention
26aftcab454
don't worry bud- WELCOME!
26aftcab454
Sounds like a hot rod-- inline merc 6 are also kwon as " tower of power"
The power packs need regular replacements seems l;ike but they are pretty reliable- you see a lot of them still running.
:cool:
jay127
ya it ran good when we tested it and i got him to drop to $1000 for the boat so i think i got a good deal. its in decent shape. Do you know if these were common motors on these boats?
26aftcab454
I think so- my dad had a 1978 --HPV175 ( bass boat ) with a 140 Evinrude with same hull dynamics - great riding boat- I love the old Glastrons- there is a web site "fiberglassclassics.com" -just google glastron & you will find it- they have a whole cult following over there!:cool: and for good reason!
jay127
So i took the oat out and it runs good. i got 38 first then we raides the outboar up 2 holes and got a better plane and hit 41. It has a 16 pitch prop on it. Is there a better prop to use to get a little more top speed.
Thanks
26aftcab454
what rpms did you get? 5,000rpm
Frank Acampora
If that 151 is a 15 footer as the numbers imply, you need to go up to a 19 or 21 pitch prop. It should be a rocket with the Merc and top 45, maybe touch 50.
My older 15 foot Glastron with a Chrysler 90 and a 21 pitch prop will do 44 and the 90 Merc should make the Chrysler look sick.
jay127
Thanks ill have to try that. I appreciate your help
jay127
Im getting really confused on the prop pitch. I've read that every prop pitch you go up is 200rpms less and every prop pitch you go down you gain. Is this right and if so how is it by going up to a 21 would i gaine spped. I'm sorry if i sound dumb i'm just trying to understand.
DuckHunterJon
Prop pitch is how far the prop will advance in one rotation - think of it as screwing in a screw. Every rotation advances the screw by some increment - that is the pitch. So turning a 19" prop one time will advance the boat 19". Turning a 21" prop by that same one rotation will advance the boat 21". In doing so, that 21" will also be harder to turn (as it is doing more work), so it will put more load on the engine, and reduce the RPM's. The goal (when aiming for top speed) is to get the max pitch that will still allow the motor to turn it's max rated RPM's.
Now, with all that said, there is another factor called slip that is the inefficiency of the prop. Think of bringing the boat up against a brick wall (not literally - ouch!), and now spinning the prop. Even though you spin it one rotation, the boat doesn't travel forward because of the brick wall. Slip rate will depend on several factors like boat weight, motor height, and other conditions.
Hope that helps.
jay127
Thank jon that does put it to perspective. I am hopefully going to install a tach this week so i can figure out what prop to use
