redneckgenius
Thread starter- Joined
- Jun 30, 2011
- 15
Hey guys, I purchased a semi project Four Winns over the winter and am in process of getting it water ready. I've had the boat running on a hose in my driveway and it runs good, but shifting into forward or reverse, really grinds. I was looking at shift linkage today and noticed that wire from + coil was unhooked. Hooked it up to white/green wire on interrupter and boat shifted fine. But after shifting, it would kill motor and not start until I unhooked it. I did a little research and got the impression that it was hooked up backwards and needed to run off the - coil. Long story short, i jumped across - coil to green/white on interruptor and immediately killed motor and cant get it to start again. Im guessing i blew a fuse, but cannot find a blown in line fuse anywhere. The motor has a 50 amp breaker on it also, but when i push it in, it doesn't feel tripped. Fuse at ignition switch is not blown either. Am i overlooking something simple or have i got bigger problems? Thanks in advance for help on this.
