My bottom cyl isn't firing anymore. Did a compression test and have 140 across all 3 cylinders, changed the plugs, bottom plugged was getting washed with fuel. I checked it for spark and didn't get any so I checked my coil, cd module for output voltage, nothing, so i checked the module on the top 2 cylinders and got 196 volts peak out of it, maual says its aceptable. I switched the modules around and the top 2 cylinders where firing so i know both sides are working on both modules (good to know my spare side works). I read in my manual on how to check the stator but not completely sure, I have 2 yellow wires and 2 blue ones, when i pulled my stator off i cann see which blue and yellow ones are paired in series, when i ohm out each series circuit on the stator one pair says 826 ohms but the other yellow and blue i get nothing, when i join both blues together and ohm out each yellow with blue only the same yellow gives me resistance. U guys figuer my stator is bad? Any help would be much appreciated. The guy at the marine shop wants 200$ for a used stator.
Mike
Mike
