1985 Force 85hp (856F5A) spark plug questions
ToonTy
I am looking to get the best performance out of my old Force 3 cylinder motor. I currently have Champion UL18V plugs in it and they seem to run fairly well. When I bought it the motor had NGK BUHW plugs in it. Yesterday I took it out and put the BUHW plugs back in it, but I could only get to 4K rpms at WOT. Pulled up to a beach and swapped out for the UL18V plugs and rps went back up to normal at WOT. The Clymer manual I have says that it should use Champion L20V or NGK BUH plugs, but I have seen posts on here sharing that people use several different plugs including NGK BUHX. When I pull up the motor on parts websites they almost all have the UL18V plug listed.
What are your thoughts? Should I try a different plug? Why would the BUHW cause the rpms to drop so much at WOT?
jerryjerry05
Sounds like one of the plugs might be bad??
Maybe change the end of the plug wire, and change the connectors on ALL
of the wires.
ToonTy
I thought that maybe one of the plugs may be bad. I will take a closer look at them later this week.
I changed all of the boots and connectors on the plug wires last season. They are all in great shape.
ToonTy
Going on a trip, but when I get back I am going to try the NGK 2522 BUHX plugs. I read in an old thread that someone said these alleviated an intermittent misfire at higher rpms. I too think that I hear this every once in a while.
jerryjerry05
When I say connectors I mean the wire ends on all the wires, stator and trigger too.
High speed miss: bad plug, loose trigger wire(under the shrink wrap), reeds.
ToonTy
Thanks Jerry! I will go back through all of the connections again to see if there is anything not making good contact.
