aymank1983
Thread starter- Joined
- Jul 11, 2011
- 1
I just bought it. took it to the sea. ran for 5min full throttle. then died.
started up again. but now it would not go fast at all. I mean I barely made it back.
It sound got but the second I try to go fast it dies, if it was a car, it feels like not enough fuel. I would like as detailed information as possible
I did some research and found that if it was running lean (from a fault in the fuel system), it could over heat and destroy the piston. ( but I made it back) well I will do a compression check tomorrow. what is the psi on these engine???
also it could be a water pump problem (is that the same thing as an impeller?).
I don't think its a water pump/impeller problem, I am personally leaning towards fuel pump or fuel filter.
I am a car mechanic for 9 years now. I am just getting in to outboard motors.
