1985 Force 85 HP Stumbles at full RPM?
Glen Grenier
My 1985 Force 85 HP runs well through the RPM range with the exception that at full throttle, the engine runs well for 10-20 seconds and then begins to stumble/hesitate/cut in out, as if it were starving for fuel. A slight back off on the throttle results in smooth operation. I have had someone pump the fuel bulb during this event and the person said it hesitated more when he squeezed the bulb. I was suspecting fuel pump capacity or something before this but now am perplexed. Again, engine achieves peak rpm and runs well for a few seconds, then "starves and picks up or starves until throttle is reduced slightly. Any Ideas? Thanks in advance.
roscoe
Re: 1985 Force 85 HP Stumbles at full RPM?
Likely a dirty sticky float needle valve in one or more of the carbs. Time to clean/rebuilt them.
