1985 Force 85 Head
jfnewell1965
My question has to do with the head on my Force 85.<br /><br />You can see picture s of what I am talking about at: http://www.jfnewell.com/boathead/ <br /><br />The following parts make up the head.<br />A = Thermostat Housing<br />B = Plate (Water Jacket Plate?)<br />C = Head<br /><br />(I left out thermostat, temp sending unit, bolts, etc.)<br /><br />There is/was a gasket between A and B. There was NO gasket between B and C. There is/was a<br />gasket between C and the block.<br /><br />In between B and C (i.e. the plate and the head) there was only "goop". I bought a gasket kit, but it did not seem to have a gasket that would go between B and C. Is this normal? Should there be a gasket between B and C?<br /><br />I found it kind of odd, that the previous rebuild had no gasket between the plate and the head, and that my gasket kit did not have one either.
roscoe
Re: 1985 Force 85 Head
No gasket there.<br />Just some "goop" to keep the water from leaking out.<br />Its a low pressure area and just needs something to fill the gaps. <br />RTV or other sealant should do.<br />Something removeable in the future would be nice.
