1985 Evinrude XP150 WOT Surging
RtyPwr88
I'm not sure where to go from here, I had it at a shop and they told it had low compression on my cylinders. My main problems are my idle when I'm not in gear it's at 1500rpms, when I get it in gear it's at 600-700rpms. The second problem is at WOT I get a surge I'll be at 4500-5000 rpm and itll drop down to 3000 and back up the other day after having the shop replace a power pack when I took it to WOT it surged but eventually just bogged right down till it turned itself off.
This motor hadn't ran in quite sometime I only purchased it a few weeks ago I had to install a new starter and replace some wires that were corroded because he had the vessel in salt water before. I have taken apart the VRO and the diaphragm looked good as well as running seafoam through the gas and changing the spark plugs. I'm just not sure what to do if I should just replace the fuel pump since to me it sounds like a fuel issue. Are my cylinders that off that it's a combination of both fuel and low compression any idea offers suggestions I've been reading the forums but cant find any numbers for the XP150. On my port side of the motor I have a reading from top to bottom of 95,95,85 and the starboard side 100,100,100. Any help is appreciated Thanks.
Wkd179
Sounds like a fuel problem high speed do you have the required tools to test fuel system?
RtyPwr88
I do not, I could get a fuel pressure reader. Right now I have taken off the carbs along with the fuel pump. Was thinking about rebuilding the carbs when i took apart the bottom carb i noticed a little piece of rubber from one of the old lines inside the carb where the fuel enters. Not sure if that was blocking the fuel from entering the carb makes me wonder.
Wkd179
Does it have a fuel filter like ref #5?...maybe on upside downhttp://shop2.evinrude.com/Index.aspx?s1=lu015efcs3p15uo9cmjmpsugc7&catalog_id=5&siteid=1
RtyPwr88
Nope I put brand new filters and primer bulb and everything is facing the correct way, the previous filter was in bad shape.
