Re: 1985 Evinrude 60 hp tilt trim relays location
The cable leading from the PTT electric motor should lead you to a quick disconnect plug. If so, unplug the electric motor.
How many wires does the electric motor have?
Now, operate the PTT up/dn switch. You should hear a click somewhere from either relays or a solenoid. Do you?
If not, someone has wired the PTT improperly which most likely will result in dangerously overheating the UP mode wire.
