I recently acquired an older boat and motor that had been sitting out in the weather for 5-6 years. The engine was infested with dirt dobber nests. I cleaned them all out and removed and cleaned carburetors. To my surprise it started, I was not expecting it to start, I was only testing to see if it would turn over with the ignition switch.
Well, when I turned it over, it started, so I quickly turned the ignition switch off because I did not have water running to the engine. I turned the ignition off and removed the key but the motor kept running. I pulled the plug wires to kill the engine, wow I felt that jolt up my arms. I ordered a new ignition switch and installed it today and the engine still will not turn off.
What is the next logical step?
