1985 Evinrude 25 HP Lower Unit Help
travisj2001
I am attempting to pull the lower unit and pulled the 4 lower bolts as well as the bolt on the upper side of the C plate. Is the shift linkage supposed to be disconnected somewhere? Some threads are saying up near the motor and others in the intake screens. I attempted to disconnect through the screens and the bolts will loosen but seems that there is resistance from the upper linkagae and I didn't want to over crank it. Any help would be appreciated.
Model: E25ELCOC.
s.hadley81
You should post this in the evinrude section but a mod will come move it for you.
