Jess5ben
Thread starter- Joined
- Aug 2, 2021
- 1
85' Evinrude, 185hp, 2 stroke
Model No: E185TLCRS
Serial No: J0425266
Outboard came with the boat I bought 3 months ago. Took it out on a lake for a week and had problems. Very different to start, had to idle very high for a few minutes then slowly ease to idle. Most times the engine would die at idle and sometime it would stay on. As the week went on the engine shutting off got worse. I would throttle down when approaching a fishing spot and the engine would shut off. Plenty of emergency anchor throws! Sometime I could not get the engine to fire back up for awhile after the engine shut off. Today I performed a compression test on a hot engine: four cylinders tested at 80 psi, one cylinder at 73 psi and the worst cylinder at 65 psi. I can not find compression specs anywhere to save my life to figure out if it's worth fixing. Figured I would start looking at the fuel lines, filter and pump if the compression is good. I would take the engine to a mech to address the low cylinder, but would really like to wrench on the rest. Please help!! Thanks!
Model No: E185TLCRS
Serial No: J0425266
