Hoping to get some help on an issue I'm having with my 1985 Evinrude 15 HP 2 stroke outboard. When I got it, it wasn't running, so I rebuilt and cleaned the carb thoroughly. Put new plugs in with fresh gas and it immediately fired. Seemed like a good sign, but I have been having problems actually getting it to stay running.
If I put the throttle in the "start" position ( as far as it allows you to turn the hand throttle in neutral before hitting the safety stop) it fires and runs for no more than 3 seconds before dying. Every time I pull the starter it does this. No matter how I adjust the low speed adjustment knob, it keeps having this issue. However, if I push the throttle down with a screwdriver (the actual lever on the carb) it starts and runs like a champ, but if I let go it will not idle, just die.
Hopefully you guys can offer some advice on how to proceed so I can get back on the water before summer is over. Thanks in advance!
