fishing again
Thread starter- Joined
- Oct 4, 2015
- 5
Ok brains, here is one for you. I have a recently purchased a 1985 Ranger 350V with a 1985 Evinrude 115 VRO so I do not have any history on the boat or motor. Here is the problem, The first time out with any length of extended run time, 8-10 minutes at 5000 + RPMS the engine started to loose power i could throttle back and the engine would pick back up, like it was starving for fuel but my glass fuel filter was full. This has happened the last 3 times I have run the engine for any extended length of time, I have a feeling it is heat related. There is a good strong stream coming from the water circulation hose on the lower cowl which I know does not prove a whole lot. Running on the muff at 2000 RPM the engine does seem to get a little hot after a few minutes so i'm thinking there is a flow problem. I am thinking rebuild the water pump, pull the heads and replace the water flow directors and the thermostats. Any and all input will be greatly appreciated. Oh one more thing, do I have to pull the power head to get to the thermostat housing I know where it is located just not sure how to go about removing it. What is the best way to get to the thermostats? Thanks
