captaincaveman
Thread starter- Joined
- Oct 11, 2010
- 18
hello i'm new to this site so i'm not sure if i posted this in the right spot but here goes, i just purchaced a 1985 doral 17' ski boat with a omc 3 liter engine this boat has 2 batteries with a big circular swith to change from batt 1 to batt 2 or all (it has 3 settings cause the guy had an amp and sub woofers) all that is disconected now probabally needs some clean up, i see a couple large wires hanging off the battery ( i assume they were for the amp) anyways yesterday i tried to hook up my radio with 2 wires from underneath the dash they came straight from a bracket that has about 20 tabs for hooking up different things i guess, so the radio worked just fine except it was continuous circut (it didn't shut off with the key) I had to shut it off manually, anyways somhow in the mix, 2 things changed the instrument lights stayed on after key was removed and the battery meter on the dash won't work anymore? i removed the radio and returned everything the way it was but it stayed like this, it was late and i wanted to turn in, i tried disconecting the main power to the ignition switch this had no affect so the only option i had was to disconect the battery so i didn't drain it, i woke up and reconected the batt and still the same thing?? on my boat there is a switch panel on the right side of steering wheel it has 6 toggle switches and then 5 round buttons i'm not sure if they are swithches (they look like it from the back) they seem to push in but none of these button switches seem to do anything but maybe they do and one is stuck on? i'm not sure, does anybody have a solution or a way to narrow down the problem? also just to let youz know i have some info handy for this boat and engine i have the origanal doral maintenance book for electrical system and piping system (doesn't go into detail about dash lights just shows wiring path) i also have the OMC stern drive operators manual, i also have the omc stern drive installation instructions for 2.5/ 3.0/ 3.8/ 5.0 and 5.7L models and i have the Seloc OMC 1964-1986 stern drive tune-up and repair manual if any information could help sombody else let me know! your help would be greatly appretiated Thanks!!
