My 85 black max will run perfect anything above idle i have elimenated the fuel system this is not a fuel problem. This problem started while i was doing some trolling. It will idle for a while when i first start it but then it just dies if i bump the throtle up to about 1000 rpm it will stay running. When it dose stay idleing it is rough and rpms go up and down some i did replace the spark plugs first thing i tried.I put new plug wires on over the winter. Thank you for your help in advance.
