1985 Bayliner 2150 cirea sunbridge engine specs
pickman58
HI I have a 1985 Bayliner Ciera sunbridge,with the 140 hp. 4 cyl. volvo. I need the engine specs.When idling,without a load I can rev the rpms all the way.But when it is under load I can only get 10000 rpms.I can't even get on plane.I don't understand why.I hope someone can help me.
DBP
captmello
Re: 1985 Bayliner 2150 cirea sunbridge engine specs
What specs do you need? I would suggest getting a manual to help you fix your engine. Those engines need to be in good tune with good fuel. Have you done a tune up on the engine? Compression test? Changed/cleaned fuel filter/s? Also, you need to confirm which engine you have. Does you engine have one carb or two?
Ayuh,... at 10,000 rpms it otta be Flyin'....
Joshua Nichols
That must be a typo or serious prop slippage..
zbnutcase
Wow! I know those Volvo 4 bangers are tough, but geez....
