1985 90hp yamaha rebuild help
knight_time
I burned up one of my cylinders not to long ago and im planning on resleeving all the cylinders while i have it torn apart. My question is what parts do i need to order is there a rebuild kit out there somewhere and more important than that if anyone has any tips and tricks to make it easier they would be much appreciated
Thanks
robert graham
Re: 1985 90hp yamaha rebuild help
Maybe it would be worth considering a good used 90HP very similar to yours instead of putting all the money into a rebuild of a 25 year old motor. If you could locate one very nearly the same as yours then you could keep your old one for parts. Just an idea, Good Luck!
knight_time
that idea has been tossed around but I got the motor cheap and was in great condition until my cooling line clogged up and the motor overheated, so i think im going to try to fix it before i go looking for a new one good news is i cant mess it up anymore than it already is
Thanks
robert graham
Another alternative might be to locate a good rebuilt powerhead, turn in yours on exchange. Could you just re-sleeve that one cylinder, or bore it out and go over on the piston? Once you find a good marine mechanic/machinist then your options may clear up. Good Luck!
knight_time
its looking like i might be boring it out .30 over
99yam40
have you checked to see if you can find .30 pistons and rings?
These are not like automotive motors
knight_time
well with the bore my mechanic said i needed to look for .75mm pistons which ive found only problem is theyre dome top and im fairly certain i need flat head pistons
robert graham
Hopefully your mechanic/machinist is experienced working on outboard motors because they are different from automotive engines.
knight_time
hes done a few of them in the past ill know more this evening when i start tearing it apart
