captain catfish
Thread starter- Joined
- Mar 19, 2008
- 23
i was really hopeful i had fixed this thing, i have fixed the charging and the tach problem. i took the boat out this morning and it ran great (1st time since the reg/rect change) . i only ran it about 15 min because of the weather. we took it out again tonight and ran it for a good 30 mins, and everything was perfect, best its ever run. until we stopped in a slew for about 30 min, when we went to leave it was obvious that something wasnt right, we could only turn 3000 rpms vs the 4200 we were turning prior to stopping.
i didnt have any test equip on the water with me, but when we got home, i check for spark (while running) some little hand held test that lights up, i have spark at each cyl. but when i pull the plug wire from 3 cylinders i get a reaction, but on the 4th nothing, i hooked up a spark test tool, and have a good spark, i didnt set it to 7/16s probably a 1/4 judging by eye, but it does have spark, i swapped leads from the power pack with cylinder above (the lower right is the problem) and plug wires, but the problem didnt follow the "coil" so i did a compression test and both cylinders were 116 and 120.
pulling the plug wire off the bottom right cylinder does nothing to motor, each of the others will have a noticeable impact on the idle, but not this 1 cylinder? someone please help me.
thanks
mark
thanks
mark
