FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
unplug the big red harness plug then jump the solenoid, and see if you have spark. you need a spark tester, and remote ignition switch to do it properly.
plug it back in an try it. if it does not work, you have a problem either in wiring harness or ignition switch, or insulation on wires inside controller. check for corroded connections.
i checked all wiring all looks good there is a two wire plug below the key and go no where it was like that when i got it also always ran rough at low speed but good at top speed
thanks
keith
