1985 90 hp evinrude no spark...please help
kevinelt
I have this 1985 90 hp evinrude vro .....at first it ran crappy(great start eh?)
then it stopped running altogether...good compression no spark anywhere.. we replaced stator brand new ...still not running no spark ...replace rectifier still not running ....did recommended test on timer base A to D no reading B to D no reading C to D no reading.... A to B 32ohms ..B to C 32ohms,...A to C 32 ohms..I can see grooves (damage) on inside of base (from dirt or debris) ...this part is expensive new ...so found one on ebay didn't buy it cause seller didn't do resistance test ....says it came of running motor...he says resistance test is sometimes not true.. and a base which fails test can still be a good working base...can anyone give me advice before I spend a fortune on this motor?
kevinelt
Re: 1985 90 hp evinrude no spark...please help
this is not my motor I was brought in to try to help yesterday....thanks for the link looks a bit better than the repair manual...I just thought I'd look for someone here more familiar with the problems of that particular model..I am really not used to that much electronics:confused:
