1985 85HP Force- Spark on #2 but nothing on #1 or #3
duck1973
Went out on the lake the other day and while towing in another boat our engine had a change in sound and loss of power. We ended up getting towed in ourselves at that point.
Now tonight I was able to look into it. Compression was good on all cylinders. I put new plugs in and checked for spark and realized I have a spark issue. My middle coil is providing spark but the top and bottom coils have no spark at all. I hooked each coil to the wire that was connected to the middle coil and each coil is working from that wire but not its original wire so I know at least the coils are good.
At this point I am lost and not sure what to test or try from here. Any help is appreciated.
Thanks!
duck1973
jerryjerry05
Check the timing?
outboardignitiondotcom has test procedures for your motor.
Try swapping the packs around and see if there are any changes??
