1985 85 hp stumbles
HAWGHUNTER88
The motor at WOT cuts out also at low speeds. It keeps running ok other than the stumble. :confused:
jerryjerry05
Re: 1985 85 hp stumbles
Could be water in the fuel.Any other info on how the boat is setup.Tuneup etc.?J
HAWGHUNTER88
New plugs, Seafoam, New gas and oil. Filters. bulb is new. #1-125 #2-125#3-125 Spark checks out. Idles fine, at slow speed cuts out and half and wot. Carbs ?
jerryjerry05
Check the fuel pump.For low speed the air screw should be set at 1 full turn out.J
