1985 85 force controls
saulgonzalez
i used to be able to pull the control at the pivot point and fast idle the motor. now after having the throttle get jammed while trying to fast idle the motor and the control arm going darn near to the floor i no longer i'm able to fast idel the motor without engageing drive.any suggestions?were would i buy a replacement?85 capri bayliner.
WillyBWright
Re: 1985 85 force controls
You won't find an exact replacement anymore. It could be a bit of work to replace it with a newer model. You might try placing rags around the mechanism and spraying it down real good with WD-40. You're using that to clean it. To lubricate it, wait til the WD dries and spray the mechanism with spray lithium grease. Both of those products should be real easy to find. Work things around as you're doing this. Chances are pretty good that will get things working properly. If not, then it's the new control option.
