1985 70 hp stops after about 15 min
jqueen
My friends mid 80's 70 hp runs fine for about 15 min, then quits and has no fire on any cyl.
Sounds like the power pack to me.
Am I on the right track?
bktheking
Re: 1985 70 hp stops after about 15 min
Probably, if you have a DVA adapter i'd test it before throwing away over a hundred bucks on a guess.
Texasmark
While you are there, replace your thermostat. I had a 75, 70 hp with a thermostat that started hanging up and finally froze shut. It would operate fine for the first few minutes then run and idle rough. Finally one day, I was doing 40 mph and the engine just siezed. Cost me an engine overhaul. I realize the thermostat has nothing to do with spark, but it may in that if the pulse module(s) get hot they may quit working and a stuck closed thermostat will surely heat up the block to which they are usually connected for heat sinking purposes.
Mark
