bargainbin2
Thread starter- Joined
- Jul 6, 2011
- 4
I have bought a 1985 aluminum bass boat I want to restore and it has what I guess is the engine that came on it a 1985 VRO Johnson with the VRO taken off. The boat is looking good so far and the engine runs good sort of. It has about 150 psi on both cylinders. I hooked it up to a set of muffs and it starts right up and idles. If I give it throttle it revs and starts to return to idle but before it returns all the way it revs high and I have to shut it down. I pulled the carburetor covers and messing around I though I would see if the carbs were sucking good. I placed my hand over the top carb and the engine started to choke down as it should. I placed my hand close to the bottem carb and it reved up high again. What in the world is causing this?
