Anthony 1985 force 50 hp
Thread starter- Joined
- Jun 10, 2011
- 1
So it just decided to start one problem after another. First it was the water impeller. changed that. then it was propeller changed that. Then it was the plug wires. Then the bolt that holds the linkage to the motor broke. Now I have that all fixed now my engine wont run at full power, also the lower gear case oil is milky and there is excessive petroleums coming out from under the cowling under the motor. Also there is the milky gear case oil streaming out of the little exuast port by the prop. At this point im kinda overwhelmed. I have been trouble shooting and repairing it more than I have got to use it.
