1985 3.0L, 140 hp Mercruiser
bird12
Put in water for first time - runs beautifully - BUT:
Can't go forward or reverse. Revs when put into forward or reverse, but no movement. Does not appear to be broken shift cable. Any suggestions??
Thanks for ANY help
Re: 1985 3.0L, 140 hp Mercruiser
Thanks for ANY help
Ayuh,... Welcome Aboard,... Pull the drive, 'n Look to see what ain't workin'...
Bt Doctur
Is this a new purchase with water test or no water test?
Did it ever operate correctly?
How did you determine its not a shift cable?
Need a bit more information to give you an accurate answer.
