FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
hi,
i have the main trim piston out i managed to remove the top spanner seal bolt and have the shaft on the bench.
how do i remove the ends on the main piston shaft to replace the small top shaft seal???
a photo, i know my explanation might sound confusing.
the seal i need to replace is sort of dangling in the middle of the shaft.
thanks again if you can help. dave
Come on guys ,
surely someone recognizes this main cylinder piston for a trim unit. I cant be the first,
it is an 85' after all, do i have a unique one???
d.
Keep the assembly in the vice, see picture...top piece are a special bolt, you might be able to use the same tools as used when you removed the whole assembly.
BEWARE !! steel balls and springs under the "bolt", not any hight tension but beware .
