1985 150hp - pop and cough but no start!
vdubbin
Hello,
I have a mid '80s (I think it is an 85) 150Hp Mercury Mariner.
When starting cold (after sitting) it cranks fine then pops once or twice (which then releases the starter) but doesn't "catch".
Every once in a while I'll get a nice backfire in there too.
What gives?
Timing? Fuel?
It seems to want to go but just cannot quite get there!
Any advice much appreciated!
Re: 1985 150hp - pop and cough but no start!
Timing? Fuel?
Ayuh,... Have you done a Full,+ Complete Tune Up,..??
Have you Checked for Spark,..?? Fuel,..??
vdubbin
Have spark, seem to have fuel...
It will pop a couple of times almost every time I'm cranking. It just doesn't want to "take off"
I have not done a "complete and full" tune up. What are the first things that you would suggest as such to address this behavior?
cheers,
j_martin
cheers,
I'm with Bondo. A full and complete tune up. The procedure will uncover the fault, but with this information, it's a complete crap shoot.
Start with checking compression. If it's not mechanically healthy, it won't "tune up", and any "tune up" items will just be a waste of time and money.
Then Check spark. Then fuel, then on this one check for reed operation.
Then you do a complete timing and linkage adjustment procedure. If it doesn't drop in, you mark off the flywheel for timing on all six, and check each one. You're looking for pre or double firing, usually caused by cracked magnets or electronics. That's not a frequent flyer, but it's happened.
The first tool you need to buy is an OEM service manual for this engine.
hope it helps
john
vdubbin
Thanks John,
I have the OEM service manual and did a pretty thorough tune last year including timing. In fact, I'm wondering if I didn't screw that up (just slightly) which may be part of my problem!
I will certainly recheck everything but even given the small amount of info provided do you have a "best guess" as to to source of problem?
Again, I can crank - get a pop or two which disengages the starter - and then the thing doesn't catch. I can repeat this over and over with the exact same behavior.
There is fuel (flooded?) and I appear to have spark on all plugs.
Oh, and the compression is good and relatively even on all cylinders.
j_martin
Thanks John,
Now we have a little more information. You've tuned the engine at one point, and this is likely a single fault.
The first thing I would do is test the starter current. It should be under 150 after an initial surge. Flip the kill switch off so it doesn't start, or use a remote starter switch.
This engine likes to crank briskly, and the failure mode for the starter is quite pernicious. They fill up in the bottom with brush debris till it slowly starts to short out. It fooled me to the point I bought a new battery at resort prices.
One of those small meters you hold against the wire should be adequate for the test.
The brushes are easy to replace, if you actually read the manual. You'll get to the strong adult beverage first if you don't.
hope it helps
john
vdubbin
Hi John,
Thanks for the reply - It would have taking me a long time to suspect the starter... on that note, I'm a little doubtful the starter is the problem. It cranks with gusto every time.
I'll definitely check the current and ALL pointers are much appreciated but would you change your suggestion slightly given a general sense that it is cranking pretty briskly - even after many tries on a not-so-new battery it seems to be turning just fine/fast...
Cheers,
sschefer
Mine does that too but I've learned that if I just hit the choke for about 2 seconds after the first pop and give it just a little bit of throttle she takes right off.
One thing you'll find is that they all start the same up to the point of running and then they all start different. :D
j_martin
That would my next quick bet before getting formal. Check the enricher valve.
hope it helps
John
gromit
I have the exact same fault with my 75hp mariner so will be watching to see if you solve this problem. Hopefully taking mine to an outboard mechanic this week so I will post the results once he has a look at mine.
sschefer
Just as a side thought. I fired up my 135 Sunday. I've been using the North River so this hadn't been started in nearly 2 months.
I hit the choke for 5 seconds. Cranked it for a couple of seconds until it popped once. I choked it for 3 seconds and cranked it until it ran for a couple of seconds. I choked it for about 3 seconds again, cracked the throttle, hit the starter and off she went.
You may just need to find the right combination to getting it started. Like I said before every 2 stroke basically starts the same but every one is a little different. The trick is remembering what you did when it does finally start.
Faztbullet
It sound like a old inline trying to start, here a trick I teach my customers yoiu can try:
1) pump up bulb tight
2) flip "kill switch" so it wont start
3) crank while holding in on choke 5 seconds
4) repump bulb
5) crank 5 seconds and then flip "kill " to on
6) crank without choking and throttle advance 1/3 open
What this does is wet the crankcase so it does not burn off the priming charge(pop & cough)
