roger3645
Thread starter- Joined
- Aug 30, 2005
- 271
I have a new to me 1985 140 looper model J140TLCOS. I have had the motor for about 3 yrs now and since retiring I've just got around to getting her up and running. She runs well on the engine stand but I'm having a problem with the power trim. Three wires from trim motor, black (ground), Blue (up) and green (down) .
Problem when I connect both the green wire and blue wire to the junction box and trim up or down the trim works real slow and everything heats up and begins to smoke. But if I just connect one wire (blu or grn) it works fine.
I am very weak at electrical issues.
I tried replacing the junction box with a known good box and relays. Same issue.
I noticed if I have the grn wire connected to the box and have the blue wire not connected to anything other than a volt meter and hit the down trim there is 12 volts running to the blue wire. To me this doesn't seem correct and makes me think the trim motor is getting power for up and down at the same time. But I don't know if this is normal.
I have also hooked the trim motor up directly to the battery and it will go up or down.
I am thinking there is a short somewhere in the trim motor wiring or in the motor itself.
Thanks
Thanks
