1985 125 hp Force won't turn unless plugs are out??
rixter
It ran fine last year, but when I tried to start it this year, the starter motor wouldn't turn it so I manually tried to move the flywheel and found it to be very stiff. I pulled the spark plugs and the motor turns ok. Could something be plugging the exhaust or intake making the motor vacuum locked?? I'm stumped and don't know much about two-strokes--so any help would be appreciated.
jerryjerry05
Re: 1985 125 hp Force won't turn unless plugs are out??
Sounds like a weak starter?
Maybe a bad battery connection?
Maybe a bad battery?
Maybe low compression on 1 or more cylinder?
Profile? Location? You might be close to someone who can help.
pnwboat
Like Jerry said, start by checking battery and battery cable connections.
dutch420
I had alnost the same issue on my 85hp and ot turned out to be a weak starter. Took the starter apart and well it was not hard to see why lol. Def check cables firsst but my 2? is the starter
