1985 125 force vs 1974 115 evinrude
Shifflett115
i have a 1985 bayliner cuddy with a 1985 125 force on it , how much difference would it be if i took the force off and put a 1974 evinrude 115 on it , performance wise
Shifflett115
Re: 1985 125 force vs 1974 115 evinrude
the bayliner is a 19 ft cuddy , the max hp is 140
Frank Acampora
Performance - wise, it will probably be a wash. the Rude will probably give equal top speed and acceleration--assuming it is running well.
But my question is: Why would you want to put on an engine so much older? Has the Force crapped out and you have the Rude lying around? Understand that the Force is relatively easy and inexpensive to restore to running condition if you do the work yourself.
Realize that with the Rude being so much older it will have more corrosion issues (assuming it has been regularly used and not lying in a garage for 15 years) and is a heavier engine. You will need to change controls, some electrical, and probably the tach, and the Evinrude is a bit more of a complex engine to work on should something happen. And, It is still a good idea to change the water pump impeller and lower unit oil. Also if the Rude has the electric shift lower unit, they have a bad reputation and parts are not available for repair unless you can find a junker.
1730V
The 1974 Rude is NOT electric shift. It is powershift II. If the controls have two cables (gear/throttle) that verifies it.
The 74 Rude is still quite serviceable. It was one of the better V-4 OMC ever built.
The 125 Force was never really 125. It's serviceable too but it was never of the quality that the Rude was.
Shifflett115
i have the evinrude sitting in my shed , it runs great . i really like the force , i need a cd box that controls the 3rd and 4th coils and i was told their really expensive , i would really like to fix it i have week spark from the 4th coil , i changed the 3rd and 4th coil around and still had week spark at the 4th coil , any other suggestions on what it would be
Frank Acampora
Is Southern Pa near the Delaware border within striking distance of you? And does your Force have the Prestolite with quick-connect fittings and black CD boxes? If so, PM me and we can try to get together. I have a few of the CD boxes and we can swap-out to see if it solves the problem.
Shifflett115
I can get to the pa,de line in about an hour , im always up for a ride , my cd boxes are black with the quick connects let me know when is good for you and we will definetly meet up and work somthing out, sooner the better, thank you very much
Frank Acampora
Private message me your e mail address and I will give you instructions to my address. I am about 20-30 minutes North of the border. Next weekend would be good since I will be waiting for another boat with a 96 Rude to repair anyway. If that doesn't work for you, we can figure out another day.
