Does anyone know the 1984 Yamaha 70 Beto Prop Shaft Thread size and pitch? I ordered a stainless steel prop and nut kit including thrush washer and spacer. Unfortunately I will still need a washer and the nut will not thread on past the cotter key hole. I suspect the nut is the wrong size at this point but I am not sure. Has anyone been through this? Should I start counting the threads on the shaft and go shopping for a new castellated nut? I lost the original one or gave it away.
