I'm new to boating so please be easy on me. The other day I took my 84 suntracker out and the 84 model evinrude was a bit hard to start in which I thought nothing about but once started I left the dock and headed down the lake enjoying my cruise after running for about 20 mins I decided to turn around and go back to a spot I seen so we could grill some burgers after being there for about 1 hour I decided to take off again and could not get my motor to start again. It was at the point to almost start but would not. After getting home I pulled the cover off to do a compression test and found one of the plugs only finger tight. My question is would this cause the engine to loose enough compression to act as it did?
I did do a compression and spark test all the cyl in order test 1. 118 2. 115 3. 118
4. 118 and as for the spark it was a bright blue almost white so it seemed ok. My next question I have some wires on my tilt and trim under the motor that look bad can someone point me in the right direction as to removing the tilt and trim so I can repair the wiring. Thank You for any replys. Tim
