lutzsucceed
Thread starter- Joined
- Dec 20, 2011
- 19
I have a 1984 3.0 Liter 140 hp w/400 Sterndrive - Mechanical Shift I believe. SELOC Stern Drive Manual - I need an OMC SHOP MANUAL....
While working on adjusting the Nominal Neutral and ESA/Overstroke set up - the shift arm inside the converter box is too far to the right and the overstroke doesn't hit the FWD Actuator even when adjusted to the limit. Also, the cable from the Remote Control Box is adjusted out to it's limit.
Does this sound like we need the Dreaded New Lower Cable? I mean, it seems as if the cables are too short - not like it stretched - if that makes sense?
NOTE: Does this adjustment need to be done in the WATER? The Manual said to hook up to the hose (which we did...) but I'm confused as to why it needs to be in the water- but will definitely take it to the lake if it makes a difference.
NOTE 2: IF it does need the dreaded New Lower Cable - it sounds like it's A VERY DIFFICULT swap and requires special tools and an OMC SHOP MANUAL?
Apologies if this has been covered many times before - I'm having difficulty finding info on my setup. THANKS FOR THE HELP!
