fburke
Thread starter- Joined
- Jul 5, 2010
- 37
I Have read the ignition trouble reshooting sticky and I have come to a point where I need to ask for additional help from you experts...?thank you Don S for the great information.
Engine 1984 OMC 3.0 OMC
Timing seems correct?when #1 cylinder is at TDC the distributor is pointing at Plug 1 and the firing order is correct according to the manual.
The cap, point?s condenser, rotor, wires and plugs are all new, replaced befoore i got the boat and from what i have observed replaced with the correct parts.
Symptom no spark using a spark tester ?. or on any of the plugs.
I have 10.8VDC on the positive side of the coil when it ignition is in the run position.
I have checked continuity through the coil and it?s good.
I have also checked resistance through the coil and it measures at 1.4 ohms.
All grounds seem good.
The only thing I noticed on the points is for some odd reason they didn?t seem to match up correctly like whoever put it in bent it, they are clean no burn marks. ?not sure if I should just replace this or if I?m possibly looking at the coil or something else?.
There is a high side and a low side of the points as the distributor turns..?I take it high side they should be open..and low side should be closed ?maybe just set incorrectly?
I?m at a loss here kind of an engine newbie so please be gentile with me
Thanks!!
Thanks!!
