snookerman111
Thread starter- Joined
- Mar 19, 2004
- 12
I have a 225 hp OMC mounted on my full transom Wellcraft 248 offshore utilizing the Seadrive bracket OMC fabricated at one time. It runs great, starts really quick etc... never had any major problems with it, until now (Have only owned it for 2 months). Even now I do not think it is a major problem, it just has me stumped, short of pulling the carbs and rebuilding them.
Heading back in from a day of offshore fishing (Good day too!) we ran for approx 25 minutes at about 80% throttle and then the engine just started slowing down, as if I was slowing the throttle down, all the way down until we came off plane and was pushing the water. I brought the throttle back to near idle position and the engine slowed to idle speed and stayed steady, slowly brought the throttle back up to full throttle, very slight increase in RPM's. Drop it in Neutral and check the throttle, it works as it should. Drop it back to the neutral position to switch into forward and it stalls. It does not start at idle any longer from this point. I give a little throttle and it fires right up, no missing or anything like that. Sounds good. Bring it back down to idle and it stalls and will not refire until I increase the throttle again. That made it very difficult to moor my boat in my slip, but was do-able. I have replaced sparkplugs, fuel filter/water separator and primer ball. Took it out to test in the river, just outside the marina and I started it as normal when it is cold (Throttle open a little with choke in) It started as it should, no misses etc.... I let it warm up about 15 minutes and then brought it down to idle and to my surprise it did stay idling, but real real low, to where it was spitting. (Lower then normal) I drop it in forward and it stalled. Restarted no problem and stalled. Not sure where to go from here, but it seems to me to be a fuel issue. I am going to check the fuel pump/screen this evening after work. the Fuel filer/water separator did have water in it. The new one I just installed has not shown any water yet....
Any ideas which direction I should head from here?
