Qbanredneck
Thread starter- Joined
- Mar 8, 2020
- 11
Hi all. I’ve read tons and tried tons but can’t find similar situation. I’ve tried dropping LU and reinstalling plenty of times, and also moving shift cables and so forth. Not sure when cables last replaced since bought boat recently. All gears worked at first, changed impeller, some lady bumped into boat motor with car ( but don’t see anything bent), the boat ran fine forward n neutral no reverse. Redid LU, took back out, reverse neutral fine but no forward. After numerous times trying different ways I’ve noticed one thing, the shift linkage is very difficult to move to forward position by hand with LU on even with cable disconnected. Once I drop the LU I can move the shift linkage fine to FNR. I’ve put Lu in forward reinstalled. It will shift into neutral and prop spins freely, but then won’t reengage to forward after that. Hope this makes sense as I’ve written and any help really appreciated. Thanks in advance
