Re: 1984 Mercury 50 HP doesn't rev very high in gear and won't plain out 17' tracker
hey just wanted to put my 2cents in I have the same problem....I rebuilt the carbs, check the compression(all good), carbs ar at 1 ? open (air/mix)..did a stator test, did a spark plug test(gap) test, check the ohms, changed the fuel pump(kit), changed all my hoses.. well as it turned out all checked out well... I was at the end of my rope and ready to step off the chair..lol when someone asked if I had check the rectifier and the switch boxes.. well that my friend is probably your problem... check your boxes and conduct a stator test... also check the wires from the trigger assembly make sure none of them are corroded... and if this does not work well I suggest that you take it to a boat mech and he will diagonose and do all these test and let you know what your problem is ?. All for about 50 to 65 $$$$ at least you?ll know what you need to work on.. now if your like me and just hate going to the shop? try doing it yourself like I did? at the end of it all you?ll know your motor inside out like I do now?lol oh also get a manual it?s a allot of help? check the high speed switchbox
