jim arthur
Thread starter- Joined
- May 2, 2012
- 3
Ok I have compression{between 132 and 135 between all cylinders}
I have fuel pressure. Rebuilt carb and adjusted to specs. Fresh fuel in a clean empty tank. New fuel filter/ water seperator. New cap/rotor/ wires/plugs. Has correct electronic conversion kit in it. Timing is at 6 deg. btdc took out on water and pulled away from dock and started sputtering when given throttle. backed off and brought up slow and was fine. but only got to about 3000 rpm . got across lake and started sputtering and died out and engine temp was high. would not start back up. Checked fuel/good . Checked spark/good . had spark at coil and not at plugs. Replaced cap rotor and still no start. Before I took it out it seemed like it would run forever on muffs without getting hot.
