1984 Jonson 15 hp help
mltessier
HI,
My motor will suddenly jump out of gear and rev up. I need to throttle down completely at that point and then I can put it in back into gear. It happens more frequently at high RPM's, but can also happen at relatively low RPM's. My question is there a linkage adjustment I can make or am I looking at a worn clutch dog? If it's the clutch dog, I've read somewhere that in can in fact be reversed. Is this right? Thank for any help!!
mltessier
Hi Thanks for the info. Hope that's not the problem...I'm in Canada bu the way. Cheers!
