1984 johnson 8hp thermostat
Thurman20
Just curious as to if these motors have a thermostat or not and if they do is there a way to clean them?
boobie
Thermostat is held under a cover on the top of the cylinder head by three bolts.
oldboat1
Unless it's a salt water motor or you are having problems, you probably don't have to pull the t.stat. But if you do pull it and plan to reuse it, it's a good idea to test it. I simply dip them in hot water and look for them to open. If you take it out, you will probably need a new gasket.
