Motor was barely turning over even with brand new battery. Replaced starter and solenoid. Turned over much better but the battery would not hold charge long enough to start it. Had a run in truck hooked up to battery and after 10 minutes boat started, ran for 5 minutes and then died. Will not start again. Tested battery and it is perfectly fine. It will turn over for a couple seconds and then stop like the battery is dead but it is not.
