Hi-<br /><br />I inherited this puppy with 1 of the 2 carbs off the motor and all of the fuel lines in the area of the carbs snipped off. I have figured out the routing of stuff with the small diameter fuel hose (to the carbs), but there is the main 5/16" line (that comes from the back of the motor where the cx is from the line from the gas can) that comes into the general area of the carbs and just ends. Neither of the carbs has a fitting to accept that bigger diameter line.<br /><br />So - the question is - how does this main line get reduced, or, in general, get gas to the carbs? I have fittings (hose barbs and a tee - all brass) that I think will work, and will then feed 2 outgoing small diameter line to the 2 carbs) but I need to make sure this is how it should be set up. I can't find s__t about this (even a generic fuel line/routing diagram udner the cowl) in the Seloc manual.<br /><br />Thanks a lot,<br />Greg
