1984 Johnson 30hp doesn't pee
Sandi
We replaced entire impellar and put new prop on-still does not pee water. We blew air thru copper tube and hoses, etc-air goes thru but no water comes out when we d the water test. Please help! The bass are biting! Thx alot!
Fouled Plug
Ensign
Re: 1984 Johnson 30hp doesn't pee
Does the motor overheat? Did you replace the thermostat when you did the impeller change? Any water in the exhaust? Can I ask anm more questions?
Sandi
Thx for the help! Nope, engine didn't overheat-will check for wter in the exhaust and didn't change thermostat-will check into all this tomorrow morning! Thx alot for the help! Happy week-end!
Sandi
Fouled Plug-Just wanted to thank you again for all your help! After much fiddlin & manual reading-finally took it in to have it checked. Just got the call and it's fixed! Hubby didn't have the key in the impellar properly! Sure learned alot about motors! The marina says she's peein' like a brand new motor! Thx again for your help! Happy fishin!
