1984 force 85hp outboard starter trouble?
MKYxD
Starter would work intermittently. Now when i try to start it throws the gear up but as soon as it feels resistance on flywheel it drops back down. There is a tiny bit of play on the starter shaft enough to make it rattle when you shake it. But the whole shaft has several mm of slop up and down. I am assuming there should be no play in it? Battery fully charges, all connections cleaned and re tightened down. So should not be from poor connection. Any other ideas i should try before investing in a new starter.
Jiggz
If you think the starter drive pinion is worn out, you can actually replace just the pinion assembly itself. The part number is F15175. You also might want to open and clean the entire starter motor itself.
jerryjerry05
Weak starter.
Loose magnets? = new starter.
A wobble on the armature? The top plate of the starter the bushing's bad and probably needs a new plate.
Clean the armature where the brushes ride.
You can buy a new aftermarket cheaper than getting this one rebuilt by a starter joint.
One in my area wants 110$ to rebuild a 100$ starter.
After it's rebuilt do a compression test.
MKYxD
Will pull starter off tomorrow and look at it. Double checked all connections still doing same thing except now when itss spinning its making a horrible sound it was not making before when it was spinning. A bearing was mentioned....it sort of sounds like a bearing spinning/trying to spin without lubrication maybe. Im at a point where i am likely buying a new starter but ill open it up for exploratory purposes i guess
jerryjerry05
No bearings in that starter, just bushings.
​Any moving parts would be the brushes/springs and the armature.
Yup take it apart and let us know.
MKYxD
Here are some pics....pretty nasty inside. will clean up some but not sure if worth saving. brushes are pretty worn but only 27 bucks for brush kit. wish i knew if rest was good
Jiggz
Personally, from the look of the armature, you'd be better off getting a new starter. It costs less than $80. And if you want to you can clean and refurb the old one as a standby unit.
jerryjerry05
THe armature needs some sandpaper and a good cleaning.
The only thing that would bother me is where the bushing is on the top cover.
If it has a lot of slop then the top plate needs to be replaced.
Otherwise the starter can be redone.
Or just buy a new one.
Brush kits on E=bay $14
MKYxD
Cleaned up and put it. Still shoots gear up and as soon as it touches flywheel comes back down. Will load test battery and check voltage at starter next
Well battery was nit charged 100% had some confusion on new charger. When it hits 100 ill see what happens and if not will bring to work to put battery on tester. And may need new multimeter as its near impossible to see voltage instantly so need a min max function
MKYxD
Battery test came back to replace battery. 550cca battery came out it was only doing 430cca
jerryjerry05
Yup a bad battery could be the problem.
​They usually only used 450cca on new boats.
That's usually all that's needed.
But yours could have a bad cell???
MKYxD
New battery in and ...... Same thing. Time for a starter. I think i will use old battery to run radio and fish finder in boat itll have power enough to do that wheres a good site to buy a aftermarjet starter. Found some in amazon but not sure if they are right one. 50-60 bucks
SkiDad
i paid around that when i got one for my dad's boat - ebay has them too
