My 84 Chrysler 85HP had some trauma inflicted to the boats original wiring harnes - an 84 Galaxie (motor harnes is OK). It has only a chrysler tach and fuel gage which seem to be the original factory units.
It has a chrysler tach but it is not connected. I was told that the tach has two functions - one is obviously as a tach, the other function is to indicate alternator operation. Are any additional wires used to connect the tach beside the black and white ones listed as tach on the motor terminal block?
A second question is about the temp sensor (located next to the upper plug). The orange wire for it comes out to the dash but there is nothing to connect it to. Is this normal or is its function also imbeded inside the tach or fuel gage? A light I cant see in daylight maybe?
Lastly, there is BIG white wire comming all the way up to the dash which ohms out to the starter relay. It looks just like the BIG white wires on the motor (insulation color, age, connector type and color). What is this used for?
Any help is apprecisted.
