heathstallings
Thread starter- Joined
- Jan 30, 2012
- 16
I have a 1984 Bayliner Capri with a Volvo Penta AQ125A and a 270 outdrive. It will not start. The engine was running great on friday. I start it up on saturday and all seems fine until I accelerate to wide open throttle. Once the rpms reach about 4500, the engine began to slow down to about 2800 rpms (throttle lever still at wide open). Boat ran great at the lower rpm. I noticed that the temperature was a little warmer than usual. It has typicall stayed about 180, but was hovering around 200 this time. The outside temperature was alittle warmer than it has been recently, so this could be the cause for that. After cruising a short distance, it backfired as I decelerated to come to a stop. After about 2 hours, I restarted the engine, but had to give it about 1/3 throttle to get it to start (not usually the case). Engine started, but ran rough for a few seconds and then died. It restarted using the same 1/3 throttle technique, but again ran rough and died instantly as I put it in gear. That was the last it has run. It will not start or even attempt to. I have tried starting fluid and checked the fuel flow, but still no change. I pulled the plugs. They looked a little dirty, but not bad. I replaced them just to be safe, but still nothing. The engine had a full tune up around September. I am at a dead end here. I have fuel and spark, but am unsure how to proceed.
