1984 75HP 4 Cylinder Gremlins
kopeck
Good afternoon,
I've had this Mariner 75HP (grey, ugly, Mercury) for a number of years and I've never been able to make it run really well. The primary thing that bugs me is it just doesn't run well at mid-throttle, say 3,000 - 4,000 RPM, which just happens to be where I like to cruse, lower then 2,500 and the boat really isn't planned out. What it does is just randomly miss in that range, you can even see the tach wiggle. Sometimes it will loose RPM too, you will be cursing along at 3,000 and then you will feel it start to miss and the RPM will drop to 2,800. Above 4,000 it goes like mad and when the boats trimmed out it sits just a hair under 5,500 RPM which is just about perfect. It also seems to want to miss more when I have a boat load of people.
The other issues I have is I can adjust the carbs so I get a good start and idle but crappy acceleration or I can richen then up a tad and get good acceleration but the engine is hard starting and just doesn't idle well.
This week it wouldn't start at all for me. I pulled the plugs and #1-#3 looked pretty normal but #4 was completely washed, no dark spot at all. I threw in a used set of buhw NGKs that I had before I realized it was suppose to have buhw-2. It started after that and ran but still had the mid-throttle issues.
Here's what I know:
I've checked the compression a few times and all cylinders have tested good consistantly. I don't recall the numbers but I'm pretty sure they were all over 150PSI and with in a PSI or two of each other.
I've rebuilt the carbs, I'm usually pretty good with a carbs and these were pretty simple. The only thing I ever questioned my self on was float level. The floats had funny bottoms on them so getting a precise measurement was kind of a crap shoot. I've also rebuilt the pump and updated the cover to the new metal one and threw that old leaky plastic job away.
It has all new bleed restrictors.
Every electrical ignition component has been changed out other then the coils. I got the engine because of mouse damage, the stator and trigger are CDI brand, the switch is a used OE Merc and it has new plug wires too. The timing was reset to service manual spec.
If I'm will to compromise on acceleration then it's a really good starting and idling engine, well as good as an old 2-Stroke can be and it runs strong at 4k and over. I don't think it's a mechanical problem. I'm planning on throwing an new set of buhw-2 in first thing since that's cheap and who knows what shape the plugs are that are in there. I may tinker with the idle circuit a bit more since that's not all that hard to do. Other then that I'm stumped and open to any ideas.
Sorry for being wordy, I just wanted to makes sure I got all the details in.
Thanks,
K
If # 4 plug looked like new then you may have a no spark condition.---Or a lower seal problem on the crankshaft and crankcase compression issues.----Reed valve problem on # 4 cylinder.----Water leaking into the engine.
kopeck
Never thought about the crank seal. That being said it sure looked like it was gas not water but I'll pull the plugs tonight after I run it a bit to double check.
I had a Force that used to eat reed valves. It kind of acted the same way just more extreme. Just looking at the part schematic, are the reeds really attached to one of the bearing carriers? That seem like a pain in the back side to check. What are the usual symptoms to bad reed valves?
K
Yes reeds really are way inside the motor on those " bearing carriers "
nhboat
i have same engine. 1986 75 merc and i have almost opposite issues. mine starts up good, runs good at idle, takes off like a bullet, and runs good at 4000 rpm or below. but she only cruises at 5000-5500 for about 30-45 seconds before she runs out of fuel and wants to stall on me. i have slow right down for her to pick up again and fill the bowls to take off again.
kopeck
I put the right plugs in and readjusted the carbs and it's starting well and has decent acceleration again. I guess it really wants that extra gap in the -2 plugs.
That being said it still runs uneven between 3k and 4k. It wasn't all that bad today but I could tell it was doing it. With the air box off it really barks in that range, I'm kind of wondering if it has a reed valve that's not quite right. It's good enough to seal at other RPMs but just doesn't cut it at mid-throttle. I don't see it coughing back though the carbs but like I said it sure growls.
I might also be kind of picky. I know this engine is a really dated design and can't hold a candle to any of the new 4-Strokes or DI 2-Stokes. It hole shots like mad, runs great over 4k.
I don't see any sign of water in any of the cylinders so that's a positive at the very least.
K
